ecu lights
mackem
I have a Toyota Hiace 2.4 diesel 1993
I have just had the ECU repaired but when I start it up the ECU lights does not go off I also have a buzz as well but goes off until rev it very high.
Can anybody help me
Was this fitted by a garage?
Who repaired the ECU?
the ecu has not been fitted wellthat is w.  can you tell me were it is on your hiace.
A guy from the Ilse of White does Toyota every day
Return the vehicle to the repairer. Explain what you have had done and your vehicle's symptoms.
