Toyota Avensis C1201 2011
Ahsan ali
Hi I had got my car serviced and also had my break pads changed from a local shop. After 300 miles all my car lights in my dash board have come on. And when diagnosed is showing the code C1201. I have gone to different mechanics and some are saying it could be yoursensors in your car or some ate saying it could be the engine that they have used . I am not able to afford the Toyota dealers fees  so if any could help. That would be great .
Search on here for it.
toyota avensis fault code c1201 someone had the same code
C1201 = Engine control system malfunction. It is a secondary code and is triggered within the engine control system by another code there will be another code in the engine ECU causing it.
Thank you for your reply . Other code is P0400 and a secondry code is C1201
Egr
Any help for this problem  please
Probably needs cleaned.could be either clogged with soot or broke. Try cleaning it first if not you can get 1 cheap from breakers
