Toyota recycle light always on?
Coolissimo
I noticed that my air conditioner was running low, as no cold air coming in, also I noticed that the light of the recycle air on the central panel was always on when I start the car so , I thought was a way to say that the Gas of the air conditioner was running low. I book an appointment to be done this job, but  the light is still on when I start the car .
Is this normal???
Thanks for the answer
Yes. It is normal when set below approx 19°C. Try raising the temperature and note the Re-circulate light will go out.
  • Like 3
Duplicate threads deleted.
Agree with Konrad above.  The system decides the best settings for the vents and air con - if the heater is set to a drastically lower temp than the outside ambient air temp, the system knows that it's easier to cool the air it's already cooled than cool 'new' hot air from outside - so it enables recirc mode.
Thanks for the answer,will the lights be on, even if the air condition is off? or even I am not using the ventilation?
Third duplicate thread deleted - please cease posting duplicate threads.
The a/light is only on if the a/c is on.
The re-circulation light will come on once the ignition is on, even if the fan is off. Same for the vent position display. The air-con only illuminates when the fan is on and A/C in use, as Alan has said. The temperature display will only show with the fan on.
Edited by Konrad C
Additional info
I dont know what is happening with the duplicated threads.It might be  a bug
There may be a bug in the system. I am only seeing one thread, but as administrator can see what is happening.
I created this thread and I did not close the page, I just refresh the page to see the answers, so I don't see how is duplicating :(, or why. Well I do apologize,  for that but, seems a sort of a bug
Have you checked and changed the cabin filter located behind the glove box. It is fairly cheap and easy to do, and overlooked!
P1070832.thumb.JPG.594798104aa80355ed91dc4b1028ae91.JPGP1070828.thumb.JPG.81cf2c5c2311dd9f36e6700699c13edd.JPGP1070829.thumb.JPG.a1f59e2707c9304a143708be2642bc19.JPGP1080253.thumb.JPG.02f4754ea0ba707261ae81495370ab7a.JPG
The photos are guides.
Hi Konrad,
Thanks once again for your help, actually I did not change it , I had already did it 8 months ago, and only cleaned it, but will buy a new one.
I don't think that it is quite this simple (at least for the climate control rather than basic a/c etc.) - I haven't fully sussed it yet but it also seems to take into account the desired temperature set & the outside temp.
If the outside temp. is higher than desired temp. > recirculate; if desired temp. is higher than outside temp. recirc. is not set - this seems to work within 0.5-1C.
(I tend to have mine set at 18C so the last week has seen outside temps. ranging from considerably below that to 26C+ which gave me the chance to see what happened if the inside temp. was set to a range of values against a range of outside temps. )
Thanks Heidfirst
