A/C problem Help!!
KhanVerso
Hi.
I have a avensis verso 2.0 VVTi 2001 model. The AC is not working. I filled up the freon but found that the AC clutch wouldn't engage. I bypassed the relay and the clutch engages. So I replaced the relay but it still doesn't engage. Also which I did bypass the relay thier was no cold air. I thought it could be the low pressure sensor but I can't find one. (Does this mode have a dual sensor only).
