Pentosin MTF2 Transmission Oil for Avensis-05?
Whetherey
Hey,
 I have an Avensis 2005 that has reached the 180tk m mark and needs manual transmission oil change according to the maintenance guide. Can I use Pentosin MTF 2 for Avensis?
PRODUCT ATTRIBUTES
Appearance Amber & Clear
Density at 15°C 851 kg/m³
Density at 20°C 850 kg/m³
Kinematic Viscosity at 100°C 7.7 mm²/s
Kinematic Viscosity at 40°C 38.3 mm²/s
Kinematic Viscosity at 20°C 88 mm²/s
Viscosity Index 177
Dynamic Viscosity at -40°C 7600 mPa*s
Pour Point <-60°C/<-76°F
Flash Point 228°C/442.4°F
Ignition Temperature 330°C/626°F
pH Value N/A
API GL-4
Toyota's own fluid is cheap enough for it and you know it's the right type you need.
