Coil pack problem
scar
Hi All, its a few years since I posted on this site and it was always in the RAV4 section. Now I have my daughters former car which she has had from new. 2011 ago fire 5 door it has served her well for 43,000 miles and I decided to keep it as the px against her new car was poor.
Well thats the intro over.
Apart from the first couple of services I have always done the maintenance myself. On taking over the car I thought I would replace the spark plugs. I know these Iridium plugs have a extended life  but I am wary of leaving spark plugs in that long. You then find out they won't free off. It a quick job air filter off, coil packs out, plugs out, new ones in. Done. Well all the 6mm retaining screw for the coil packs didn't want to come out. Eventually I got 2 out but cylinder 1 refused. The brass female fitting that the bolt sits in just turns inside its housing. I don't know if it was a interference fit or glued but it just spun in its pocket. I cut the head of the bolt off which allowed me to draw out the coil pack. I then had to drill out the seized bolt and re tap it 6mm. It took awhile. The plugs were in pretty good condition but I put the new ones in.
So a word of warning, you may be unlucky like me and not be able to get a coil pack out. It may be worth removing the 6mm bolts and put your favourite form of anti corrosion paste/fluid on them. I was just unfortunate. Toyota put brass female fitting to prevent this happening but there has been some sort of galvanic reaction between the bolt and its brass fitting. I came close to drilling out all 3.
I filled the car up and on the first tank of petrol did 433 miles. 35.36 L of petrol went in. Now that surprised me as the official tank size is 35 L. Anyway that is 55.7 mpg all around town, pleased with that. Our other car is a Honda CRV petrol and we average 33 mpg so thats not getting much use at the moment.
Overall I am very pleased with the car. Its never been back for any problems usually attributed to this model,  the only big item was new front discs and pads which I did. Its  basic inside but as a cheap form of transport with 5doors, no road tax and cheap insurance it puts a smile on my face when I drive it.
Must sort my avatar info out, sold that car years ago.
Edited by scar
Avatar info incorrect
Glad you got it sorted in the end. Getting my plugs changed by the Toyota dealer in December, at the five year point. Like you, I don't want the plugs getting stuck in there, for me or the next owner.
Wish i was getting 55 mpg though, I must have a heavy right foot :blink:
My packs were quite troublesome to get out as well (although luckily without snapping anything), and I agree in changing them more often than the book suggests if only to re-lube eveything. I have always used copperslip in areas like this, having had a sparkplug sieze many years ago on an Escort Mk1 that I vowed I would never let happen again!
Funny that MPG should be mentioned - I just filled up the other day and checked MPG (I haven't done so for ages) and saw I had achieved 61mpg! I wouldn't say I was particularly light footed either, although I was getting around 55 when I was last checking. I have a feeling the cat removal may have helped though.
According to the Toyota dealer full service schedule, which I had done last year, they are supposed to check the spark plugs. Whether they actually do or not, would probably mean sitting there watching them carry out a service. I had asked for a 'My Toyota' video of the service, but that never materialised.
The plugs are getting renewed on the next one, just to make sure.
What interval does the book suggest?
