blue smoke on initial start upT180
mikeversot180
hi I own a Toyota corolla verso T180 every morning when I start it up a get a puff of blue smoke then that's it no more just on the initial start up is this normal thanks mike
not sure but it happens sometimes just after the car warms up then that's it until next time I start it from cold have you got the same car as me ?
Most likely causes:
Leaking injector, this drips fuel into the engine after shut down which then burns off at start up ( either 1 of the 4 engine or the 5th exhaust injector ) - have the injectors removed and tested by a Diesel specialist.
Leaking Turbocharger, oil seeping past seals in the Turbo which burns off after startup - have the turbo inspected for obvious leaks ( some oil is ok ) check for free play in compressor shaft
Leaking valve stem oil seals, rare never seen it on an AD diesel engine - if not the above you could try seal conditioner in the engine oil as a temporary solution if it stops after using the conditioner then a cylinder head rebuild is required to fix permanently.
