Internet Problems
breezer
Hi there
right, just got a new PC! put all parts in meself and running fine.
not sure if youve heard of a game called battlefield 1942 or not, but my internet works fine before it, but when i go into a server on battlefield to pay a game, it says failed to connect to server, so i close it and all my internet has gone off.
why does it do this? :ffs: one of the main reasons i bought this PC was so i could play this game.
someone must know :ph34r:
RU ON DIAL UP OR BROADBAND ??
you dont have to turn firewall off!! gooood no!
Just forward the ports that the game uses...
Just search for battlefield Ports, then look in manula for router/firewall to figure out how to forward the ports.
Cheers
Matt
how would you get the game to work from a network, assuming ICS is disable, and there is a proxy server running
im on broadband and dont have any firewall or spyware things on that i know of! i havent installed anything like that!
so how do i do that matt?
have you got a router? gateway? some broadband modems have hardware firewalls
Try 192.168.0.0
or
192.168.0.1
If they dont work.... find out yourself :lol: :lol:
i have a router because my brothers computer is hooked upto it!
i am master computer, where the router and modem is!
You might find this useful in regard to your router
http://www.portforward.com/routers.htm
You still need to find out ports of Battlefield Vietam, AND what your network Ip is..
not your internet, So you can open access from outside through the battelfield port, to YOUR I.P. only
This should look simular to 192.168.0.3 or thereabouts....
If its 123.456.345.343 (that style) you are using wrong ip.
Cheers
Matt
nah no router, the server is connected to the net
the car PC, other PC and laptop use the net by connecting to http://server_name on port 8080 (this works ok)
games on port 1080 but it doesnt work, even tried with both firewalls off
Cheers
Matt
vaules for each sub parts can only be 0-255
ohh yeah good point, but i was just telling him to make sure he uses his Network I.P :thumbsup:
Just there to make a point
local net do not need to start of with 192. I have use 168 and 10 in the past
