Exhaust Bore Size For Sera?
tonnie200
My girlfriends car failed its MOT on a blowing exhaust and no fog light.
The cars got a backbox done from powerflow. I doubt its that cheap to get a standard UK toyota sera exhaust anyway, so better going for custom. What bore diameter should I ask for to make the car go a wee bit faster?
Where can I buy one of those rear fog lights from?
Thanks,
Tonnie
sorry to hear that mate.
Andrew does full stainless systems for the Sera, so he's really the person to answer this one.
As far as rear fog lights go, there are a couple of options here.
1. fasten one to the bottom of the bumper...Looks terrible, but it's all you need. Foglight/accessory light kits from Halfords or Motorworld contain the switch, light , relay, wire etc for a tenner or so.
2. tint one of the reversing lights at the back and redo the wiring to it.
3. Put some permanent foglight fittings into the rear end of the car.
If you check the gallery for my car you can see what I did with mine. Gen7 Celica foglights mounted into the rear bumper. Not cheap, but they look right.
Rich
I have the Sera exhausts copied in stainless steel, in stock as well. Increasing bore size will not really do much for power.
Front section £ 205
Cat bypass £ 55
Centre £ 84
Rear £ 205
All in stainless steel. All plus VAT I'm afraid :-(
  • 11 years later...
The post with the parts in question is over 11 years old, so it is doubtful the parts are still available.
