Looking At An 87 Celica
blueripper
194km
-new spark pluges
-new spark pluge wires/ and distr-cap
-pretty new breaks all around
-pretty new clutch
-pretty new head gasket
-new speakers all around (ultimate) life time warrenty
-pioneer deck DEH-P4600
-GTS seats
-fog lights (wires all run, just need to be hooked up)
-safty insp(good till DEC 31)
-Salvania Head lights(******en bright assss)
-just got a full inspection from Certigard
-cut the shifter a bit..little shorter
-Ravtive shifter/ boot
Interior is in great shape, one vent is trashed on the passanger side.
Body is in good shape, only rust is a little on the sun roof
Problems:
-E-break light is stuck on..the e break doesnt rub or anything..soo...
-the oil gauge turnes on when u turne on the car...but then it just dropes back down to zero after 3seconds
-when u are on empty and put $6 of gas in it, the car runs awsome, runs perfect, smooth and just hums along, when u full the tank, the car spudders, i think there is soemthing wrong with the full pump. the car runs, just a little rough, needs to be adjusted, or replaced (would ahve gone to pick your part and got one, but i am not driving it right now soo, and dont have the time.
-and needs new tires, the ones on it are pretty bald.
He is selling for 800 cad.. im thinking buy it? and do the timing belt and clutch over the winter, and drive it for spring or around there. It would be my first car.
Does anyone know wats wrong with the car? more then 5 or 6 bucks in gas and it spudders.. he says fuel pump maybe but my dad said its not that.
Ill post pics if u want.. it has NO rust.. just rust on the sunroof..
194km
-new spark pluges
-pretty new clutch
-GTS seats
Problems:
You want to be checking that the seal on the fuel tank filler is good and that the return line to the tank is clear. Also might be worth changing the fuel filter and draining the tank. Its possible you could have water in the system. :thumbsup:
