Toyota Supra Turbo
Ash2005
Hi I need to replace my clutch and while I am at it flywheel. I bought the car just under two years ago, always having Supras since 1996....
The guy I bought it from was a racer and its just given up on me. My car has been off the road for many months and now I want to bring her back to life. I have investigated race clutches and lightened flywheels in the US. I wonder is there anywhere in the UK that can supply these race spec parts or do I have to shop abroad? :unsure:
I have emailed many places but thought I could ask here for maybe a suggestion or help? Its a 1990 single turbo 24 valve, G reg, 7mgte, UK spec.....I dont want a normal stock plate because Id rather buy a stronger part....
Many Thanks
Ash :thumbsup:
Fensport do a clutch kit for an Ma-70 turbo :thumbsup:
If you are gold you get 10% discount.
N/A ctuch/flywheel is totally different, so you have been warned!!
Many Thanks
Ash :thumbsup:
Thanks alot m8 :)))))))))
[/quote
THANKYOU VERY MUCH :))
No worries :thumbsup:
I just had a butchers, They do the kit...
Uprated Road Clutch 3.0 Turbo: Using a 4 Paddle Cerametallic Sprung Centred Drive Plate and a modified standard cover £305.00
With gold membership you will save over £30, and it costs £25 to join....
So nows the time if ever ;) (no, I'm not on commision)
I got a supra turbo flywheel machined and lightend by 1KG for about £40 In all honesty in most applications, you'll not benefit hat much from the lightened flywheels, the 7M-GTE engine is a low revs high grunt affair, Along with the fact that a paddle clutch will make it more "stallable" as it is!
:thumbsup:
