Sound System Advice
mrrandom
I have no real idea with sound systems, and would really appreciate it if sum1 with a little knowhow could let me know if this stuff is compatable??
here are the links:
THE HEADUNIT
KEN-KDC3027G
Security: Face off
Power Output Per Channel: 45 W
Pre-amp Outputs: 1 sets
Pre-amp Output Voltage: 2 V
CD Changer Controls: No
Remote Control: Hard Wired Option
Internal EQ/Crossovers: Yes
Aux Input: None
Illumination Colour: Green
Facia Finish: Silver/Grey
headunit
THE AMP
MAY-QXA250
Number of Channels: 2
RMS Power (4ohms): 50 W
RMS Power (2ohms):
Bridged RMS Power (4ohms): 150 W
Quoted Max Power (4ohms): 300 W
Speaker Level Inputs: No
Pre-amp Outputs: No
Built-In Crossovers: Variable
Bass Boost: Yes
Dimensions:
http://www.caraudiodirect.co.uk/product_in...?products_id=37
THE SUB
http://www.caraudiodirect.co.uk/product_in...roducts_id=3585 Sub
The 6x9's
http://www.caraudiodirect.co.uk/product_in...roducts_id=3578 6x9's
Final Price = £169.96 good or bad or what??
ive also got a 6 disk changer, would that be able to be connected into all of that??....
someone please give advice, need it badly!!
You've answered your own question :ffs:
:lol::lol:
All the rest should go together alright, but you won't be able to use your CD changer with that H/U. The headunit only has ISO connectors on the back with a single stereo line output for you amp.
You may need a Y-Split Phono lead in order to get both channels of you amp working.
If you want your changer to work, you will either need to find a H/U to match the changer or get a changer adaptor control box from Halfords or Autoleads to intergrate it to a H/U of your choice. The only thing regarless is that the H/U has changer control function.
HTH
