What Should Be The Tyre Pressures ?
bhargav_mist
Hi friends,
I just bought a 1994 Toyota corolla and i was wondering as to what should be the front tyre pressures ??.
can anybody out here pls help me with the pressure figures.
Thanks in advance.
bhargav
have a look in the area about the hinge on the drivers door - most cars have stickers about there.
Usually hig 20's or low 30's depending on useage (higher on M'ways).
And welcome ..
Hi and welcome!
You could also try inside the glovebox on the bottom of the bit that opens - that's where mine are.
Hope that's some sort of help!
Cheers,
Alan
off the top of my head.. i think it's 29psi front and 30 - 31 psi rear... but check 1st though.
generally 30 psi all round is fine under normal driving conditions.. a couple of psi either way to suit your own driving style won't do the tyres any damage.
Thye should be in the glovebox or the owners manual!!!
Im some cars they are inside the fuel flap!
hi all,
Thanks guys for all the help i will surely check the values and will post the exact values..
Thanks lots guys !!
B
Tyre Pressure for a 1.8 litre 1994 Toyota Corolla are:
Tyre Size
155 R 1378S (Front)30psi (Rear) 29psi
155 R 1382S (Front)26 (Rear)24
165/70 R 14 81H (Front)36 (Rear)36
165/70 R 14 81T (Front)36 (Rear)34
175/65 R 14 82H (Front)36 (Rear)34
185/60 R 14 H (Front)30 (Rear)30
185/65 R 14 85H (Front)36 (Rear)34
all pressures are in PSI
Sorry about the layout
Data From: Auto Data CD
