Cam Belt Snaped At V High Rpm
johnsuzi
:unsure: have just snaped the timing belt on our celica 2.0 gt (3s-fe)engine i,m hopeing that after reading some of the post,s on the site eg non-interference that there may be some hope,so what i,m asking is after checking for siezed pullys could i try to just re-fit a new one and see how it goes,or strip it down and check thank,s for any info john ps apologys for not changing the belt straight away,if i,d botherd to look i,d ave seen it was in real bad condition anyway had the car for 3 months so my fault realy cheers
don't know if it's a non interference engine or not, but it's worth a try just putting a new belt on.
If the engine hasn't sustained any damage, then you're away.
If not, then you'll know when you start it up !.
Either way though, you'll have to fit the new belt sometime ;)
or you may have bent half the valves, and doing this my bend the rest of them and cost you twice as much.
i suggest you wait for some one who knows about this engine.....
can't you turn it over by hand first to make sure verything is smooth? I thought after you put the belt on, you disconnect the Battery jack the front end up and then turn it over??
May be wrong? I helped my father in law change one a few years ago
At high revs, If your going to damage 1 valve, you`ll more than likely have damaged all of them.
can't you turn it over by hand first to make sure verything is smooth? I thought after you put the belt on, you disconnect the battery jack the front end up and then turn it over??
Yep. You can do this. But again. At high revs. The engine will have completed quite a few revolutions with or without bent valve. So you`ll only notice a lack of compression if anything.
Put simply. Best way is to line everything up to the timing marks,Pop the belt on, try to start it. If it runs ok thats good, but do a compression check anyway, if it`s lumpy then again do a compression check, if it doesn`t start at all whip off the head and pray that not all 16 valves have gone. :unsure::thumbsup:
:D thank,s to you all (re 3sfe) ,i took daktari,s advice and just done timeing mark re-fited cam belt and it started sweet as a nut,so i,m over the moon although it took me longer to get the top cover off due to one 10mm bolt opp the brake master cyl than the rest of the job,so thank,s again ps it,s well worth the membership fee,s to get your input as garage is about £35 per hour so iv,e saved to date about £95 in advice
Excellent news. Glad it was all ok. Thats the beauty of TOC. Best web site ever IMO :thumbsup:
