16's On A Yaris.... Need Some Help!
patty
will 16's fit on a yaris 1.3 sr??
what offset would i need for a 6.5j rim with a 195/45/16 tyre??
I'm also considering lowering the car at a later date on coilovers so i guess i may need a specific offset if i plan to do this in future??
thanks in advance!!
patty :D
Yes they will fit on a 1.3
the pcd needs to be 4 x 100
and the offset is 38, but 35 - 42 will fit fine, and i'm sure they shouldn't interfere with your coilovers. It's 17's that may cause a problem on coilovers with a higher or lower offset than 38
moffmo's quote from a previous thread
45 is defo pushing it and youll knaker the wheel bearings in no time at all
42 is not advisable
38 is spot on
PLEASE USE THE FKIN SEARCH BUTTON! :ffs:
It sounds like someone's in a bit of a mood :angry:
Almost worth posting another question from that list to see if I can hear you scream from here! :lol:
