Urgent Help Again!
Lia TOC
Hi all AGAIN!!!!
oK, lexus lights on, green wire on car connected to green wire on lexus light. Green and white wire on car connected to green and white wire on lexus light.
Break light works, side light works.
Indicator doesnt not work.
indicator at front of the car works, but not a rear. HELP!
Hi all AGAIN!!!!
You might have blown the bulb?
Swap it/test it....just to make sure!
Hi all AGAIN!!!!
Swapped it and checked it. Not a fuse :(
Is there anyway of checking that your getting any voltage on that specific bulb holder?
Wiggle the wires around a bit? as it might be a lose connection?
You could do with a multimeter by the sounds of it :thumbsup:
how far away from me are you if you want to travel to me ill do them for fre but i cant do them from the top of my head sorry
you could get a multimeter from a DIY shop for about £5 least you will know if theres voltage there and you learn a bit at the same time. :thumbsup:
try the hazards does that work?
check there is a good connection on the plug, fiddly little buggers they are
like lee says, and i said to you yesterday, impossible unless you know what your doing. offer still stands 1/2 an hour and they will be working.
