Susension Set-up's
Baby Yari
t-sport has different mounts on the front compared to all others
konis are adjustable on the rebound rate ;)
on the front?
so techicnally.. mine shouldnt fit...?
:P
dunno
i can always remeber theres two different part no.s for TS and non TS
think they may be slightly shorter to be honest as the TS chassis does sit 20MM closer to the ground
i think your talking about the rear ones jaxx, the mounts are the same its just the length if i remember correctly.
the blisteins designed for 1.3s fitted on lees car, its just the back was too long so pushed the rear end up
Shut up Moffmo. :rolleyes:
The rear dampers on a T-Sport are shorter and it'll look daft if you put a damper designed for any other Yaris on the back. All the rest is the same, even the springs! :thumbsup:
thats what i said you !Removed! !Removed!
but coilovers are ADJUST A F A BLE
You said it after about 8 replies though Matt! Why didn't you say it in the firstplace 'you !Removed! !Removed!'? :rolleyes:
Mine are coilovers so there! :P
On mine? Yes because they are coilovers! A YTS would still look too high with mine on though! :yes:
