Bye
vmail
Bugger, I'm off again soon. Dunno where I am going and I've got a day to do the job
Hi Nadim,
Hope you had a nice time over the holiday period.
The Fire Alarm interface for O**** V****** which you and M*** worked on in December needs "installing" in early January and requires someone from A** to go.  This person will be you as I had very good reports and was very impressed with how you handled yourself on MY S** e****.  The install is mostly concerned with getting the software working and demonstrating its usage - the unit will obviously need to be located and connected as well, but it is not like the AV install work which was required on S** E****.
The best plan will be to get you to fly from Manchester early on in the first full week after New Year (i.e. around 9/01/05) so you can go home at the weekend and go to the airport straight from your house after the weekend.  The install should only take a day or so.
M*** was working on a user Manual which can be left with the Crew.
I will see you in the new year and will discuss the plans further.
Kind regards
J**** W***
Huh?? i thought Vmail covered those due to privacy?!?!?!
J
yup, customers yacht/ferry name and staff names
