Need Some Help
hoho15
hey ive got a friend who does powder coating and he offered to do my rocket cover(i think thats what people call them, well thats what he called it) for me for 20 quid but ive heard some info off my mate is that if i take my rocket cover off i would have to replace the gasket, is this true? if so how much is a replacement?
many thanks hoho!
depends mate. most toyota engines use a rubber rocker, or cam cover to give it its proper name, gasket. if so and it isnt to brittle then youll be ok.
if you want to be sure get one from Mr T they shouldnt be too dear
i think what Dawsey meant is that the gaskets are rubber, the cover is aluminium, if you powder coat it/them it will retain heat more (not much) it will be better to go for a metallic powder coat to stop this
ic but my main question was when i take the rocket cover off will i need 2 replace the gasket? sorry if i wasnt clear
"depends mate. most toyota engines use a rubber rocker, or cam cover to give it its proper name, gasket. if so and it isnt to brittle then youll be ok.
if you want to be sure get one from Mr T they shouldnt be too dear" Dawesy
What he said :)
