Turning Right
elgonko
wonder if anyone can help/has experienced the same thing?
not alswys but sometimes when i turn right theres a noise coming from the front drivers side wheel.
it sounds like something is rubbing on the disk or something but i've looked and checked everything and it seems to be fine.
any ideas??
cheers
ross
Just a thought. It maybe the back plate rubbing that is rubbing on the disc. try bending it away from the disc and see if that helps.
Hope this helps
Mart
i notice a little noise when in full lock (both sides)... a sound similar to tire rubbing against wheel arch ... but i know it can't be that as the tires are nowhere near the wheelarches.
I had the same problem with my corolla mate, its a 1995 E10 1.3 16v. It turned out to be the drivers side CV joint, not sure if it will be the same with yours but i had the same noise and the same problem
any ideas??
cheers
ross
I've had 3 cars from 3 manufactuers with the same thing. It only happens when its on full lock and ur still applying pressure.
Does it on both side of all 3 cars so i'm guessing its not a problem and something that just happens.
Try putting it on full lock then apply a bit more pressure on both sides. should do the same thing
cheers for the replys.stripped everything tonight and found it was the wear indicator on the pad that had bent and was touching the disk!
dunno why it only happened when turning right tho.
cheers anyway
ross
I notice the same noise when turning full lock to either side, raise the issue to the dealer but they said they couldn't find anything wrong. I guess it's normal...
any ideas??
cheers
ross
any ideas??
cheers
ross
