Weird Ringing Noise From Car
Johndcfc
Hi All,
Wondered if anyone knew what this weird sound was - I've only noticed it when on motorways / dual carriageways.
Its like a ringing metal type sound from the back of the car?
Sorry I cant be more specific but its completely random....
Thanks in advance...
John
  • 4 weeks later...
hiya
i get hum/ringing noise at around 90 - 110 miles an hour. I think it is the roof whip aerial. I took mine off and replaced it with the shorter bee sting type ( as on type R civic ) and it stopped
Unscrew it off and go for a spin - then you can tell for sure
hope this helps
hiya
hope this helps
LOL at that speed all I can hear is the engine and exhaust!!! :lol: ....and my ears are the only thing are 'ringing' :D
So true K19 LOL- and it is probably why i dont hear the aerial ringing as i try to go faster - the engine/exhaust sound drowns it out!!.
hiya
hope this helps
Thanks, I'll give it a try although I was convinced it was coming from the rear wheels....
Next question, what aerial did you get?
hiya
hope this helps
Use 6th gear then :D
John
hiya
hope this helps
hiya
hope this helps
John
That is in 6th gear!!! Have you heard the K&N Typhoon kit coupled with the TTE back box!?!? :eek: Coasting along is fine, but once you even attempt to put pressure on the pedal the hummm is actually quite nauseating at times! :fear:
good advice for k19 - nice one John;-)
The aerial i got is about 6" long - you can get them in Halfords. But i kinda liked the stubbier ones on the honda civic - tested one from my bro's type R and it worked so got one off eBay - approx £12 with post! - they are £30 in a honda dealer ( he got his nicked ha ha ha)
Just checked eBay - tons of these aerials but not the honda civic type.
hope this helps
The aerial i got is about 6" long - you can get them in halfords. But i kinda liked the stubbier ones on the honda civic - tested one from my bro's type R and it worked so got one off ebay - approx £12 with post! - they are £30 in a honda dealer ( he got his nicked ha ha ha)
Just checked ebay - tons of these aerials but not the honda civic type.
hope this helps
On the 6th gear issue... I find 6th gear isn't nearly tall enough for motorway driving...
On the 'which aerial' issue... I tried the stubby aerial from a Lexus IS200 and it looks much better... might 'swap' mine with my mates and say nothing! :lol:
You should check the rear brakes:
http://toyotaownersclub.com/forums/index.php?showtopic=48913
'CTS03': See my reply to the post you're refering to above...
hope this helps
Thanks, I'll get one on eBay.
Have to agree, everyone comments on how noisey it is while cruising on motorways.....
Thanks, my dad thought the same but I've not had any vibrations just the weird noise. I'm going to take it back to the dealer this weekend and see if they can find a solution as its still under warranty.
Cheers
John
Found the problem.....
It was the toolkit in the boot (next to the spare wheel) rattling as some of the tools hadn't been secured properly!
:lol: :censor: :lol:
