4age Ae82 Engine Rebuild + Gearbox
Ae82Mad
Hello peeps.Does anyone know a place where i could have my engine fully rebuilt using stock parts and gerabox? Any one here had one done? Know of any names? any help much appreciated.regards The Ae82 Lover !!!
:thumbsup: hi, try BRADFORD GRINDERS in BRADFORD.
The was a place adverting on eBay a little while ago, didn't give there addres just said e-mail if interested, west midlands somewhere.
http://cgi.ebay.co.uk/civic-integra-vtec-b...1QQcmdZViewItem
4age engine kit
Complete Gasket Set
Cometic Head Gasket(or copper) these can hold 35psi of boost or almost any compression ratio)
ROSS Forged Pistons
81, 81.5 Bore & 8.2-1 comp)
81, 81.5, 82 Bore & 9.1-1 comp)
81, 81.5, 82, 82.5 Bore & 10-1 comp)
Performance Rings (plasma ring)
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs £660 plus shipping
Is that the sort thing you were looking for?
would love like to give mine a rebuild as done over 120K, but havent really got the money at the mo.
Regards
Phil.
The was a place adverting on ebay a little while ago, didn't give there addres just said e-mail if interested, west midlands somewhere.
4age engine kit
Complete Gasket Set
ROSS Forged Pistons
Thrust Washers
Timing Belt
Regards
Phil.
thanks for the reply,but i want the engine pretty standard,no forged pistons etc.Any one else? thanks
surely if you're going to go to the expense of a rebuild, you may as well get it uprated? I can't imagine it needing one otherwise?
Well if drop them an email and ask they might be able to do standard parts for you, what the worst they can say (no). But i'm thinking standard parts could end up costing more than uprated parts.
Regards
Phil.
