Advice Please
dieselman
my yaris T3 Diesel 04 uses super Long Life coolant and in order for me to top it up. I have to buy a 5Ltr can from Mr T because there is no smaller amount. to buy apparently. as 5 Ltr cost round about £40 I find this a rip-off. any suggtestions as to what I can use ? :help:
Thank-you
How many Mr Ts have you tried. Prices really do vary, so it would probably be worth shopping around a bit.
Is your car using coolant, or are you just looking to change the existing stuff. If its using it it may be the symptom of an underlying problem and worth a visit to Mr T with the car.
There is a coolant that some of the T-Sport guys swear by, but I can neither remember the name of it nor find it on the Envy site. Clarky certainly has it, but it involved a full drain and change.
Actually, whilst looking through the Envy site they have 5 litres of the Toyota stuff as described for £18 (+p&p) so it sounds like you're getting robbed. Here's the link to it on their website:- Clicky!
Hth,
Alan
Yep. You are being seen off with £40. I paid 17 someting + VAT for 5ltrs from my local MrT :yes:
Evans Coolant. :thumbsup:
That's the one!
A
Is this the normal toyota red longlife coolant? If so MrT in northampton is 17quid for 5 litres and envy is 15.
£40 will be the Pink coolant found in most newer Toyota's, apparantly it should last the whole life of the car :blink:
In Toyota's infinite wisdom aswell they haven't made this available in 1ltr top ups.
Surely you should be able to an unbranded oem coolant to the same quality level from a motor factor in 1 litre packs??
I wouldn't go mixing coolant to be honest, it can turn the coolant all gunky and thick blocking pipes causing overheating etc.
I would always say use one brand of coolant only.
