Swap Injection Pump -> Engine Won't Start
Niels
After swapping the engine (complete with injection pump), it won't start.
It seems there's a problem with the link between the fuel cut valve control and the transponder key.
Is there any solution known for this problem?
Specs:
Carina E 2.0 Turbo Diesel
1996, 61kw, engine type: 2C-T
Details new fuel cut valve control ('cause it's kind of blurry)
Toyota
89850 - 20011
102366 - 0032
DENSO JAPAN
BOSCH
0 281 005 023
10-12-97
28SA 2979
00958
Thanks a lot.
Regards,
Niels.
Specs:
Toyota
89850 - 20011
102366 - 0032
DENSO JAPAN
BOSCH
0 281 005 023
10-12-97
28SA 2979
00958
Thanks a lot.
Regards,
Niels.
[/quote
try and swop them over. Toyota used shear bolts as it is part of the immobliser system. You will need to drill them out.
  • 10 years later...
Exactly the problem am facing right now here is the picture of my pump.
For my condor 3ltr.
