Show
Malfunction Indicator Lamp
  • Please log in to reply
14 replies to this topic
#1 bobbarnes
bobbarnes
    Club Member
  • Registered Member
  • PipPip
  • 58 posts
  • Toyota Model: Corolla 2.0 D-4D
Posted 11 November 2006 - 04:44 PM
This indicator light has just come on. Does anyone have any experience with this ?
The car seems to be performing normally. I've had no problems in the 13 ( !?! ) months
of ownership and it had its 3rd year intermediate service a month a go.
#2 dovlagsi
dovlagsi
    Club Member
  • Registered Member
  • PipPip
  • 20 posts
  • Toyota Model: E11 Corolla 1,4 VVT-i 4-dr
Posted 12 November 2006 - 12:17 PM
Go to toyota service maybe?
I know I did so, and it was something stupid.. like minor electronical mix up.
#3 bobbarnes
bobbarnes
    Club Member
  • Registered Member
  • PipPip
  • 58 posts
Posted 12 November 2006 - 12:26 PM
Did thay charge for a minor fix like that ?
#4 dovlagsi
dovlagsi
    Club Member
  • Registered Member
  • PipPip
  • 20 posts
Posted 12 November 2006 - 11:45 PM
No, it happened about a year after I bought my 'rolla.
Warranty covered all expences.
#5 bobbarnes
bobbarnes
    Club Member
  • Registered Member
  • PipPip
  • 58 posts
Posted 15 November 2006 - 04:57 PM
I can see this turning out to be a right pain.
Phoned the dealer and although they'll take my money for servicing they're not equipped
to run diagnostics on the car. Told me I had to go halfway across London to another one
of their dealerships.
:angry:
#6 bobbarnes
bobbarnes
    Club Member
  • Registered Member
  • PipPip
  • 58 posts
Posted 17 November 2006 - 01:06 PM
Well I've been quoted 100 quid from Jemca just to check the code.
Anyone know if these things come on because the service interval has been reached ?
#7 ahmed
ahmed
    Club Member
  • Registered Member
  • PipPip
  • 37 posts
Posted 17 November 2006 - 01:49 PM
the MIL light doesnt come on if service interval is reached. it only comes on if a Fault Code is pending. It means the the oboard computer has detected a fault. just to get the code read by the dealer costs an arm and a leg. personally i'd recommend buying a home scanner or a cable and read the fault code yourself and then you can pay to have the fault repaired rather than paying for the code to be read and then paying for the repair.
#8 bobbarnes
bobbarnes
    Club Member
  • Registered Member
  • PipPip
  • 58 posts
Posted 21 November 2006 - 11:52 AM
I think you're right. I ended up going to a local garage and payed 40 quid. Mind you it took three different
testers before the mechanic could make the connection to the computer. Maybe the the codes for the 2.0 D-4D are not that widespread. Just a guess.
Anyway it was a fault on one of the glow plugs which he said might or might not be a "real fault". He cleared the error and it didn't come again on this morning which considering it was fairly cold looks like a good sign.
Apparently it will cost 160 to replaced the glow plugs which sounds a bit high .. ?
#9 bobbarnes
bobbarnes
    Club Member
  • Registered Member
  • PipPip
  • 58 posts
Posted 22 November 2006 - 05:18 PM
Well it's back on. :(
I have a PC. Anyone know any good OBD software I could install to double check this for myself before forking out for a repair ?
I also understand that I'd need a USB to Serial converter.
#10 ahmed
ahmed
    Club Member
  • Registered Member
  • PipPip
  • 37 posts
Posted 26 November 2006 - 11:18 PM
I use a software called EngineCheck, it works well for me.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
