Thinking Of A Mr2 Turb......
Mackers
As I Said Above, thinking of moving over to the MR2 Forums, as opposed to the Avensis ones, lol, (bit more Street Cred), anyways, anything to look out for??
Basically i'm lookng at a 2.0l Turbo White/Black or Met Green ideally, about a 'K' Reg with Air-Con and ideally all the toys/extra's, for around the 4K make not too bothered about it being STD, cos i will be modding it in the future, jus wondering when i'm looking round if there was any issues to keep an eye on, apart from the usual:
rear tyre side walls, gaps in body panels, rattles, pulling to 1 side when driving, oil leaks.
Any Help Greatfully Accepted and hopefully i'll be on here soon with my "2"
Wayne
Mackers
there are a few buyers guides out there mate. Google
lol what he said, but if i was you with 4k i would try to find or if not stretch a little further for a revision 3
better turbo
better manifold
no cylinder faults?
better ecu cos they use map sensors instead of !Removed! maf
i think suspension and brakes were further improved
more power from standard
revised (ino) better looking spoiler
when test driving remember to check the rear for any knocking noises as those will be the top mounts on the suspension.
check for uneven bodywork repairs that may have been made etc. the usual stuff really
buy mine ;)
http://www.imoc.co.uk/forums/viewtopic.php...652&start=0
anyhow, things to look out for are
oil leaks
crunching in gears
clutch slipping
smooth idle
knocks, rattles from engine
blue smoke from exhaust
turbo boost smoothly between 2.5k to 6k
a well looked after one will be fine, an abused one will suffer from one or more of those
Get in Contact with Rash... He will easy be able to source you a Rev 3 Tubby with a budget of £4k.
Infact he has one in at the moment a black Rev 3 T-bar Turbo for Sub £4k. :)
Check this link out to some of his cars he has at the moment. Loads of people off here have bought from him and are very happy with their Purchases.. :)
http://toyotaownersclub.com/forums/index.php?showforum=101
sound advice :yes::yes:
jerry!!
Lads, cheers for the mint advice, when did the Rev3 Come out?? what age onwards i looking at, also, i got an Avensis to part ex, i think i forgot to mention it B4.
october 93? you might be lucky to get a 93 that is a........... K reg?
But best thing is to get a L reg onwards one then you're garaunteed a rev3, 1994 onwards are all rev3!
Thats MAP sensors!!!! WOOHOO!!!! and better turbo, turbo manifold, more power!!!! Easier to tune too!
  • 3 months later...
october 93?
Correct......I had a Dec 93 :)
KiwiMR2
Damn lad.. not seen you on here for ages.. how you keeping? :D
Hehe....yeah been a while aye, not bad down my end of the world thanks :)
MR2 has gone now but thought I'd check in & see if there are any new names kicking around in the MR2 section....looks like there is :thumbsup:
Got the 2 featured in a NZ car magazine & basicly the day the mag was released I had an offer on it & just like that it was gone :unsure: I e-mailed the guy who brought it in Decemeber for an update (he was planning on getting it dyno tuned with the PFC installed) and it turns out it has been off the road for a while, he found it had low compression on cylinders 2 & 3....turned out to be cracked ringlands so needed either a rebuild or replacement :eek: he opted for a new engine & had a crack at installing it himself etc.
I replaced it with a Mini.....it's a 79 but in reality it's 90% mid 90's with a fuel injected cooper motor & pretty much everything else from a newer 95/96 roundnose. We JUST in the last 2 months sold the Glanza with the intention of replacing it with a station wagon (starting a family) and recenlty got a Libero......couldn't without a turbo so made sure the wagon had one ;)
I'll set up a thread with the new wheels as I'm sure they are either non existant or very rare in the UK so probably of interest B) (Libero GT
I'll have to have a read around & see what all the old fellas are driving now days....I see Jimlad has a batty now!!
KiwiMR2
What is a batty?
My first car was a Mini, 1980 850cc, loved it... might get another as a project car.
What is a batty?
Batty.....Batmobile; RX7 ;) I think you guys call it a "rex"...to me that means WRX though :D
Yeah I've had a few mini's over the last few years but settled finally on what I'm happy with B)
1979 Mini Cooper.....modified with a mid 90's cooper fuel injected motor, and virtually EVERYTHING else from the mid 90's mini I could take across!! Also added 4 good Speakers, Pioneer MP3 headunit, amp & sub, and an alarm.
KiwiMR2
