Avensis Fuses
avensis owner
:help: Does anybody know where the fuse is for the cigarette lighter on an Avensis D-4D T3x RHD.
I've accessed the panel under the steering column and the description on the panel leads me to believe I stubbled on a nuclear physics formula. :unsure:
Thanks :thumbsup:
Thanks :thumbsup:
:D
hi the fuse box is located behind the glove compartment- you will have to open the compartment and remove the screw on the strut and then wiggle the glove box about to get the 2 stops past and remove glove compartment -cig fuse is no.44 i think (15 amp)
