How Tofix My Rev Problem
JC Wasp
hi there. when i start up my 92 levin she revs at about 1000 to 1500 revs till shes warm. then she drops right down to 500 revs and then drops every now and then and feels like shes bout to cut out. ne ideas on how to fix this?
Could be -
Vacuum Leak somewhere
Bad AFM
Idle valve controller (if it has one)
If my Sera is anything to go by, the initial revs should be higher than 1k ( 1.5k ish ) till it's warm, then dropping down to about 800ish.
As Leeky says, check for vacuum leaks and electrical connections. That's definitely the first place to start !
Good luck
