O/d Light Flashes
collywobbles69
O/D light flashes when the truck is in overdrive.
Hi there. I own a Toyota hilux surf
Can anyone alert me to the reason why O/D light flashes when the truck is moving in overdrive? O/D is not affected at the mo but wondering if I can sort it out myself? :o
It doesnt mean you necesserily have an o/d problem - the light is the atm equivalent of the engine warning light
u do whatever u do on your car to read engine codes - short pins - use an OBDC II tool - to flash or read ATM codes from the o/d light
the fault will be a speed sensor, 3 I think - solenoid or limited slip diff transfer solenoid (Rav has one not sure about Hilux)
When I had this it was actially a blown transistor in the ECU that was actually quite easy to fix with an easy to get transistor from a radio shop -- they recognised the number on it as standard electronics markings no Toyota specific code
