Finally Finished!
john905
Good stuff, running ok???
I'd get rid of that HKS air "filter" though... They are utterly useless!!
yeah running fine, what would you go for a standard box or another filter??
Also if i get a standard air box might have to put Battery in boot due to lack of space
cheers john
Nice job :thumbsup: any interior mods ?
glad to see its done dude, does it drive well?
std air box is good but just an apexi filter mounted in a cold air box would be fine. the filter where it is is going to suck in a lot of hot air.
look forward to seeing it in the flesh some time
yeah drives well thanks and its rapid had a very big smile when i first took it out have got a slight prob its over fueling when i give it the big un i get a little pop of black smoke its on std 1.6 corolla fuel pump not sure if the 205 does but the 185 runs 9v at pump and switchs to 12 when you boot it we by passed it so runnig constant 12v dont know if bigger injectors will help
yeah the 205 runs a fuel pump resistor too. you really could do with a mappable ecu on it to be fair or rig up the fuel pump resistor. 3s-gte's tend to run rich on stock ecu's anyway
ok mate will have to look into it what you upto on the 4 th of april they have got run what you brung on at santa pod i will be there i fancy seein what 1/4 mile i will get
Well done mate looks good :thumbsup: You must be really pleased.
jerry!!
if me engines built and run in ill be up there
