• Review Your Toyota
      Review Your Toyota
    • 1000's Of Toyota Cars For Sale
    • Join Premium & Save
      Join Premium & Save
    • Get Your Club Gear!
      Get Your Club Gear!
    • Save Up To 15% Off For Members
    • Huge Range of Toyota Parts
AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Sign in to follow this
Followers 0
Alan Thomas
Yaris Engine Management Light
5 posts in this topic
Hello, My engine management light just came on my Yaris 1.0 (1999), any ideas how to reset or what the problem may be?
Share this post
Link to post
It could be any number of things. You either need to take the car to a garage or buy an OBD2 code reader to read the error code yourself.
If you search the threads, you'll see that there are severay common faults - many times its the MAF sensor, but without reading the code you don't really know.
There is a way to reset the light that you'll find in the threads (I think its something to do with disconnecting the battery) or the code reader can be used to reset the light too.
If you're very careful, you could try cleaning the MAF sensor and resetting the light, just to see if that fixes it, but you need to be careful with the MAF sensor because you can easily ruin it if you touch the sensor wire.
Share this post
Link to post
I have a toyota yaris 1.0 litre gls.
yes my car is fixed. to get the engine managment light off is to get the eml wiring by-passed to somewhere else, then you will never see that light come on. Only when you switch on your car!!! so they didnt take the bulb out.It is a electrical fault that trips off from ecu, get this wire traced and job done.
i had this problem for 6 months, i had a new after market cat, bank 1 and 2 oxygen sensors replaced, high octain fuel put in and so many times to take off the fault codes po4 somethink off at the garage.
i have the same car and never see that anoying light come on again.
Thanks to Spiros Garage fault finding team
Share this post
Link to post
Not really a fault finding team, they just by passed the bulb, you still have the fault but no warning. Now any fault will not be relayed back to you.
Share this post
Link to post
As Pinkbits mentions, that does not sort the problem, more like brushes it under the carpet!
What happens if the car develops a serious fault and the light cannot come on to warn you? :rolleyes:
Up to you though, your car and all that.
Share this post
Link to post
Followers 0
