Show
Please Help Me Replace Brake Light Bulbs!
  • Please log in to reply
24 replies to this topic
#1 PrinceOfDarkness
PrinceOfDarkness
    Club Member
  • Registered Member
  • PipPip
  • 38 posts
  • Toyota Model: 2.0 Avensis Spirit Tourer
Posted 05 April 2008 - 11:39 AM
one of my brake light bulbs have gone, so i'm trying to replace it. i can't figure out how to get the bulbs out of the car! i've taken a pic to show you the rear light cluster from inside
i think you have to fiddle with the prongs but i can't figure it out
any help appreciated as i don't want to get pulled by the cops!
thanks
Posted Image
#2 gazza1286
gazza1286
    gazza1286
  • Registered Member
  • PipPipPipPipPipPip
  • 787 posts
  • First Name:Gary
  • Gender*:Male
  • Toyota Model: Avensis 1.8SE (2000) and MR2 MKII - Rev4 (1996) ; Avensis 1.8 TR 2008
  • Year: 2008
Posted 05 April 2008 - 12:30 PM
Prince
I don't have your model, but check the Owner's Manual. Toyota always give extensive instructions as to how to change all light bulbs. (at least for all the cars I've owned)
#3 Penfold
Penfold
    Advanced Club Member
  • Registered Member
  • PipPipPipPip
  • 122 posts
  • Toyota Model: 1998 Avensis 2.0 GLS and 2001 Corolla GLS
Posted 05 April 2008 - 02:55 PM
As gazza says - check the book as the instructions are generally clear.
From the picture it looks like you have to pinch both prongs in each set together and pull it out of the cluster. You should then be able to acess the bulb to remove it as usual (push, twist, pull)
#4 T600
T600
    Top Rank Poster!
  • Advanced Members
  • PipPipPipPipPipPipPipPip
  • 2,965 posts
  • Gender*:Male
  • Toyota Model: Auris T180, MR2 GT T-Bar
Posted 05 April 2008 - 03:04 PM
As they said - owners manual is the place to look.
On quite a few Toyotas you have to unbolt the entire cluster before you can change any of the rear bulbs. That may be the case with your car.
#5 cmia
cmia
    Top Rank Poster!
  • Registered Member
  • 1,314 posts
  • Toyota Model: avensis
Posted 05 April 2008 - 03:40 PM
pinch the connectors
pull..
change the bulbs
press in
#6 PrinceOfDarkness
PrinceOfDarkness
    Club Member
  • Registered Member
  • PipPip
  • 38 posts
Posted 05 April 2008 - 06:41 PM
ok thanks guys
the manual isn't great to be honest. having said that, it doesn't appear to be a complicated job, but you can't get both your hands in a position to grasp both prongs at the same time! i'll give it another go tomorrow
thanks again
#7 JWL
JWL
    New Member
  • Registered Member
  • 15 posts
  • Toyota Model: Toyota Avensis T4 Tourer
Posted 31 March 2009 - 12:17 PM
thanks
Posted Image
Did you manage to do this? I have exactly the same problem. I tried Toyota World in Solihull, they said that it would take 15 minutes for their technician and cost £20. I find this absolutely ridiculous to change a simple light bulb. I tried Halfords who offered to change it for £3 but failed to manage it. So, I plan to have another go. It looks like I am going to have to dismantle quite a bit of the trim in the boot. The manual is hopeless, there is just one picture which is less clear than yours. There are a few arrows which suggest that you need to push the prongs apart while pulling the assembly out. I can't manage this through a hole which is only just big enough for one hand. Your picture helped since it makes it clearer that the prongs probably need to be squeezed rather than pushed apart. I tried again and for a moment thought that I was getting somewhere but finally I had to give up.
I am very disappointed in this car. I bought it second hand as an approved used car from a Toyota dealer. I had hoped that it would be boring, cheap, and reliable. It has only managed one of those (guess which). I had lots of problems with it. They were all fixed under the warranty but it was very time consuming and irritating.
#8 Heidfirst
Heidfirst
    Top Rank Poster!
  • Registered Member
  • 2,095 posts
  • First Name:Scott
  • Gender*:Male
  • Toyota Model: Avensis TR Tourer 2.2 D-4D (now sold)
  • Year: 2007
Posted 31 March 2009 - 12:39 PM
changing lightbulbs on recent cars (not just Toyotas) doesn't seem easy.
I recently upgraded the front bulbs in my Avensis which was very fiddly & tbh we (I had a car literate friend assisting) gave up on the parking lights as we just couldn't get the bulb sockets to turn as the manual said ...
Following that experience he went to check on his Volvo & I checked on my mother's new Focus - on both you have to remove the whole front light assembly from the car to change bulbs (the Volvo seemed to have a lever, the Ford involves a screwdriver).
#9 JWL
JWL
    New Member
  • Registered Member
  • 15 posts
Posted 31 March 2009 - 12:50 PM
True. I had a Volvo V70 before this Toyota. It was also very hard to change the bulbs but, if I asked the dealer nicely, they would change them for just the cost of the bulb. Prior to the Volvo, I had a BMW525 Estate, and I could change the bulbs myself. I am not getting another Toyota. I also said that about the Volvo but if for some reason I had a choice of only the two, I would go for the Volvo. I should have stuck to BMW. The 525 was my third and I liked all of them. This is not just because of the £20 bulb change, that is just the last straw.
#10 Aamir2892
Aamir2892
  • Registered Member
  • PipPipPipPip
  • 338 posts
  • Gender*:Male
  • Toyota Model: Avensis Tourer T-Spirit 2.2 D4D 2005 (55)
  • Year: 2005
Posted 31 March 2009 - 04:08 PM
You pull the four long tongs then it should come out. Took me half hour to do mine first time. VERY fiddly with one hand. When you put it back in make sure you do it correctly. I ended up having the indicator bulb in the housing so i had to take the whole lamp housing out to get the bulb out!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
