Led Dash...
H_5hum
Hi
I couldnt find anything on this forum about this topic, (maybe i didnt search hard enough) but i was wondering if anyone has changed, or thought about changing their Front console lights to LEDs? I mean the middle section where the air con button is, the Heater controls, and the small display and the buttons around that?
Im thinking of changing them to LED's to make it look nicer? I was looking on the Vauxhall forums for my brother the other day, and came across this pic, and thought it would be a bit different to change the Yaris ones as well?
Any advice would be greatful :) Thanks
If it's a P1 Yaris, it's just a coloured bulb which you could swap for an LED + resistor
Thanks for the reply! :) but mine is a Phase 2 though. I'm just going to experiment a little and see what i can find.. There shouldn't be much of a difference between Ph1 & 2 i think? Someone on here can tell me if I'm wrong or not? :P
yeah it is possible to change the bulb`s to LED`s but you would probably end up "hard wiring" the LED & resistor to the side lighty circuit because it would be quite difficult to get one to work off the circuit board that the normal light slots into. Don`t forget to get the polarity of the LED the correct way around because it will only work one way around. Good luck :thumbsup:
Thanks Benno_uk, will give it a try, but i havnt done anything thing like this before, so will have to take a gamble!
  • 2 months later...
i have changed all of mine to leds and its not hard and looks awesome, im in t/wells too so if u need to see or any help just give me a pm
