Rear Window Winder Disconnected
mucker
Hi all,
Today, the rear window winder mechanism failed on my 2001 Avensis. Having managed to prise the door panel off, I discovered that one end of the wire had become disconnected from the mechanism. After untangling it, I've no idea how it all goes back together.
Does anyone have a diagram or photo of how it supposed to look? Any help or pointers is very much appreciated.
Thanks,
Rich
P.S. I've managed to secure the window shut by using a bolt through a hole already provided - thanks Toyota!!!!
  • 11 months later...
I've got a similar problem with my '02 Avey GS. After removing my left rear door card, I see the cable has snapped. Does anybody have a diagram for the winder cable?
I guess the easiest thing to do is to check the other rear door
and see how the wire should be routed.
