Estima Rear Strut Broken
Mark44
My rear left strut is broken. Is it safe to drive until I can get it fixed?
What's a reasonable price to have it fixed?
Do you have to do both sides even though the right is okay?
My rear left strut is broken. Is it safe to drive until I can get it fixed? no
What's a reasonable price to have it fixed? £0 would be good failing that £70 upwards i would imagine
Do you have to do both sides even though the right is okay? better to change in pairs ie both fronts or both rears
What does your logic tell you???
Ask youself how valuable your life is and then based on your answer you decide on the rest.
New struts can be had from your local motor factors. As far as I know the Estima uses the same ones as the Previa but you will need to know if you have a solid axle or independent suspension in order to get the correct ones.
