Hand Brake Adjustment
bokdrol
Hi there! Can anyone please tell me how to adjust/ tighten the hand brake setting on the Avensis 2001 Model? Cheers, Martina
The handbrake operates on a pair of brakeshoes inside the rear disc. (drum-in-disc)
The adjuster is accessed via a hole in the disc inbetween the wheel mounting bolts (wheel needs to be removed)
I am sure that there are some pictures posted on here if you search for them.
Found this for you,
http://toyotaownersclub.com/forums/index.p...p;hl=rear+discs
Also from the same thread, this has pictures which should explain it for you.
http://toyotaownersclub.com/forums/index.php?showtopic=84814
This actually shows changing the discs but you can sift out the relevant info for the adjustment.
