Do I Have Sat Nav
gseka2009
hi, i am new to this so i am sorry if the answer is already on the forum. i have just bought a avensis verso 05 and and have found a dvd sat nav under the seat and then i have found a book saying tns300eta does this mean i have sat nav? thanks for any help.
If there is a disc in it, then yes you do. If there is no disc in it, then no, you don't & you will need to purchase a disc. But unless the disc is current, your sat nav will be 4 years out of date in terms of road changes, one way systems, roundabouts etc as it is a 2005 car. So I would use an independent Tomtom or other system, as the discs are expensive for Avensis at over £120 each update.
Hope this helps.
Cheers,
Marama
Thanks if i was to get a dvd what one would i need to get? thanks again.
Have you actually tried turning the satnav on or ejecting the disc? It may have a disc in there already.
is it buy pressing the navi botton and i canot see how to open the sat nav sorry?
To geska2009,
You should have a sliding catch on your sat/nav, once this is moved if you have disc in unit it will automatically emerge. Use the following link to verify disc required www.toyota-mapupdates.eu. But as suggested by other postings your sat/nav is an early version & the discs are a complete rip-off. Treat yourself to something nice from one of the major car component factors instead as suggested by other postings.
Regards, Beagh.
To geska2009,
Regards, Beagh.
To Beagh
thanks i have moved the catch and no disc but i put a disc in to see if it was working and it would not take it in. I have seen disc on eBay would they work?
To geska2009,
I cannot advise you as to eBay. But what i would say is phone or take your vehicle to your nearest Toyota franchise & let them run a check. At least with Toyota you know you will be buying the real item, or you can say no if disc is to pricey. If buying of eBay make sure it's the real thing & ask seller how he know's this, if no return answer, don't buy.
Regards, Beagh.
To geska2009,
I cannot advise you as to ebay. But what i would say is phone or take your vehicle to your nearest Toyota franchise & let them run a check. At least with Toyota you know you will be buying the real item, or you can say no if disc is to pricey. If buying of ebay make sure it's the real thing & ask seller how he know's this, if no return answer, don't buy.
Regards, Beagh.
Thanks Beagh
some great advice thanks again for the wise words i will go to my nearest dealer and see what they come up with. just out of curiosity should i see some thing to indicate that the dvd player is working like a light on it?
regards,gseka
To geska2009,
Regards, Beagh.
Thanks Beagh
regards,gseka
Hi the sat nav in the toyotas are quite good. But dont work in north or south of ireland for some reason. Toyota dont supply a disc for these areas either...dont figure :unsure:
As thatch suggests discs are a bit hit & miss for use in Ireland only showing main roads in my case ( N-Roads ) yet disc checker suggests they cover much more, you should not have this problem living in the UK? When turning ignition to first position (without starting car) you may hear noise from Sat/Nav as if unit is doing a search. No lights, your split screen in dash will confirm if you have disc, if you have not then no info will show.
Regards, Beagh.
Regards, Beagh.
Thanks again i must not have a disc, no info on screen but i should still hear a noise from sat/nav unit shoud i be abel to load a disc though?
Regards, Beagh.
Just a update on my problem i have disc in unit but cannot get it out,and when i press the navi button still no display for info any ideas on how i can manualy get the disc out ,how i know that the disc is in their i have had the face plate of and can see it again many thanks for any help.
Regards, Beagh.
On the 300 does it have an eject button behind the sliding catch?
Regards, Beagh.
On the front panel behind the eject button it dose have a small button and i have pressed it and still no movement of disc!
To geska2009,
Have double checked the way my sytem works (same as yours) and with ignition key in 1st position with dash facia lighting up you should hear a noise the same as a computer hard drive doing a search & Toyota Navigation System should come up on your split screen. To remove your disc, key again must be in 1st position as above & when you slide Grey? slider across disc automatically comes out. I can find no seperate fuse for sat/nav, but it works through audio system when using voice control for guidance so it must share same circuits as radio at some point. Fuse for radio is behind glove/box, but if your radio system works i think your option know is to return vehicle to Toyota & have them check for a 12 volt feed to sat/nav unit. It is possible that you have a faulty unit ie: no power feed or jammed disc.
Regards, Beagh.
To geska2009,
Regards, Beagh.
Thanks again i will take it to them to have a check i think that it a power fault but i will let them look at in before i brake it again many thanks for all your time.
To geska2009,
Regards, Beagh.
Sorry for a new update but i have managed to get the disc out of dvd don't realy know how but it came out but new problem can't get it back in again any help before i take it to garage. i do have power going to the unit i put a tester on the unit and had power but donot know how much.
To geska2009,
Regards, Beagh.
If you've just recently bought the car, isn't it under warranty? If it is, just let them sort it out for you. I presume that now the disc is out it is the correct disc in there? It should just feed back into the satnav unit in the same way as any cd/dvd player.
To geska2009,
Regards, Beagh.
I will have to check if my warranty covers the sat nav. But the disc just won't go back in again thanks for support.
To geska2009,
Regards, Beagh.
If it's Toyota used car warranty the only exceptions are Battery, Exhaust, wheels and tyres. Otherwise it's the same as for a new car (unless it's changed since I bought mine)
To geska2009,
Regards, Beagh.
It's not but i will still give it a go and see what they say thanks again GSEKA.
