Buying Advice On A 99 Avensis 1.6
hamish262001
need some advice any common problems found on a 1999, 1.6 manual, petrol, saloon, GLS i think?
the car i have already looked at has 120k miles
has a knocking noise at the left rear
exhaust leak in the rear
has the noisy steering colum so i will pack that with 'toyota steering colum grease'
anything else?
Cheers
Ask if any work has been done on the ingnition. Not sure excactly what the problem is, but both mine and my brother's Avensis 99 had problems with the ingnition, allthough they don't share the same engine. Mine being a 2.0, his being a 1.8.
Oh, and timing belt ofcourse
By ingniton i mean the starter engine or the starting system
To hamish262001,
From memory potential ignition problem is caused via disc at base of ignition unit playing up when key turned, not a major problem. Knocking noise from rear could be rear A/R/Bar bush or link, they wear pretty quickly front & back depending on condition of your local roads. They are a very good all-round car but as with anything of a certain age watch out for rust & general wear & tear. As with all cars make sure all paperwork is in order & carry out HPI check.
Regards, Beagh.
anything else?
Cheers
hello
what about maintenance log book for this car? have you got it from previous owner?
it will answer all your questions. if not, even all owners will advice you the clear picture will be disclosed after detailed examination oof the car.
it is my opinion.
cheers/Igor
