Fifth Gear Jumps Out
dazboy
Can anyone advise on the problem of the fifth gear jumping out on a two litre T spirit
It will run fine if I hold the gear stick in firm but it jumps out as soon as I let go.
It will also stay in place when de accelerating say on the motorway but as soon as I accelerate it pops out………any advice please?
hello
it is never mind what is the engine volume -- in case you have this issue -- it means the fifth gear fixing device got a problem.
cheers/Igor
hello
cheers/Igor
Like Igor says, problem is probably with 5th gear synchro hub. Thrust on the gear is in the opposite direction when decelerating, so stays in.
