'00 Avensis Gs Alloys
Flex
Edit: I've worked most of it out myself with some more research.
I still need to find out what the correct offset should be. Any help? On this topic, aven_man states that an offset between 35 - 48mm will be ok, but the last thing I want is to spend in excess of £500 only to have silly looking rims.
I had these in mind: http://www.wheel-base.co.uk/proddetail_fit...prod=17Ace205HB considering that according to the site, they will fit.
I've also found these: http://cgi.ebay.co.uk/17%22-Alloy-Wheels-B...9QQcmdZViewItem
^ 38 mm offset should sit nicely on the car right? :)
Year : 96>
PCD : 5x100
Offset : 35 to 45
Bore : 54.1
Recommended fitments,
15" 195x60/15
16" 205x50/16
17" 215x40/17
18" 215x35/18
Year : 96>
PCD : 5x100
Offset : 35 to 45
Bore : 54.1
15" 195x60/15
16" 205x50/16
17" 215x40/17
18" 215x35/18
Thanks. Maybe there should be a sticky with all this information on? :)
