Font Disc & Pad Wear ! !
Kcs
HI, i was looking at buying a 57 plate Avensis 1.8 TR, after a quick test drive i
noticed that there was a grinding noise when applying the brakes, i told the sales
man this and he said the car had stood for a week and they just needed to be used
to clear them off, maybe i tought to myself but they still grinded the same when we
came back to the dealership ! I had a look at the disc's when we got back, they
looked very scored and marked, some were quite deep score marks ! again the sales
guy said it was normal, ok i said and whent over to a couple of other 07 plate Avensis
and looked at the disc's, both cars had brand new disc & pads ! the guy told me that
all the cars had covered around the same miles, ( the one i drove had 16,300 ) Is this
normal for the disc's to be changed at such low miles ? Is this a known Avensis problem ?
Any help appreciated
Kcs
My 07 plate 1.8 has now covered 22K miles, ex-Toyota car with 15K on when I bought it, still on original pads with some way to go yet. They always make a 'grinding' noise for a while though, on first driving after being left for a week or so (as mine frequently is).
Badly scored discs would be a concern though, I would think.
Kcs
hello
normally when the car is iddle for a long time all discs become rusted especially when the climate is foggy.
it is admissible that several brakings can arise specific noise. besides each pad has steel wear indicator. have all pads inspected on wear down rate. may be this is what we are talking about ???
cheers/Igor
I'm assuming you are looking at cars from a Toyota dealer - round here similar cars are given a full check over by the dealer before releasing.
If you spot small faults like paint scuffs etc - pointing them out to the salesman should being the reply - ' we will sort that out in the paint shop for you '
While it is true about the discs rusting while standing, if there is obvious deep grooving, request that they be skimmed or replaced - the workshops just turn them down a fraction and fit new pads.
If they won't address your concerns - walk away - plenty more around - its a buyers market !
Thanks for all your reply's. did not go back to main dealer to buy this car, plenty of them
around ! will compare other cars that i look at in the future !
Kcs
Kcs
hello
in case your heart gives you an advice --- go aahead to anothers.
good luck !!!
Igor
My discs rust after a few days standing in the damp. The first time I use them maybe even second there is a little grinding then its fine.
it is absolutely right
Igor
