Glove Box
davemh
I have an Avensis 04 plate T3-X. A small but annoying little problem, how to change the glove box light? I suspect there is a connector but as the cable loom is tight & I can't withdraw the fitting enough to see. Anyone know?
If you remove the trim just above the glove box, you should have more access to the light fitting which is at the front where the glove box shuts. There is a connector , which you will have to unclip by pinching either side of it from the rear of the fitting. Hope this helps.
Thanks for your help. – problem resolved. I removed the glove box & went in that way.
