Oil Cap Leaking
marco polo
the plastic oil cap is leaking oil on to the top of the engine compartment i think it is a seal or something gone anyone experience this with avensis
Not on any of my recent cars but did a couple of times on older cars.... its easy, replace the ring seal or the entire cap :)
yes the task is for pupil.
just have an oil resist rubber sheet with thickess as yours.
have it replaced
Cheers/Igor
Try a new cap, if it still leaks the engine may be breathing heavy.
i took it for a drive it stopped leaking i will check it tomorrow thanks lads for the feedback
hello
pay attention on the condition of both surfaces -- may be small part remained that prevents tightness.
normally this O-ring gasket serve for a long time.
cheers/Igor
