Avensis Auto Will Not Start
Bengun
Hi everyone,
hope someone can help me on this one
I have an Avensis 1998 CDX Auto, I have a problem with starting, It will not start in park or Neutral, I had the RAC out and he said it was the isolator switch that stops it being started in gear. He rigged up a temp wire from the relay to the Battery which starts the engine. Can anyone tell me the exact location of this switch, as I cannot see it. is it on the gearbox or at gear leaver?
Many thanks
John
Hi everyone,
I have an Avensis 1998 CDX Auto, I have a problem with starting, It will not start in park or Neutral, I had the RAC out and he said it was the isolator switch that stops it being started in gear. He rigged up a temp wire from the relay to the battery which starts the engine. Can anyone tell me the exact location of this switch, as I cannot see it. is it on the gearbox or at gear leaver?
Many thanks
John
John hi
Do you have some principal drawing?
May be this question is abnormal - but it is so hardly to imagine it.
This whould be help to start thinkiing.
Cheers/Igor
I seem to recall it being called the 'inhibitor' switch :huh:
I am sorry to say that you need to have a search through a workshop manual to locate it :(
Thanks for this info I have been onto Toyota since and they have called it the same thing, They are currently faxing me the Tech drawings but they did say the switch is £250 + Vat :angry:
I have been told you can rig up a push button swith you gust have to remember be in park or neutral :)
Thanks for your help
....but they did say the switch is £250 + Vat :angry: ....
Ouch that is painful :crybaby:
I hope it all goes well for you :thumbsup:
