Ermm Help!
Omasis`
Just been out changing my brake pads when disaster srikes and my heart sank as i have snapped one of the bolts that holds the caliper in place what would be the easiest solution? :(
erm...damn bro if you can jack the car up turn the wheel if its back try and get some room to get proper access to it.
Get to a drill and use a extractor to undo it....However i reckon this might be a tricky one as those bolts are hard to open. Maybe get the car to a garage or get a mechanic home.
managed to retrieve the bolt with my fingers :o after i paid £8.50 for bolt extracting drill bits (always the way) so now its just a case of getting a bolt from toyota in the morning thank god for that :yahoo:
