Bye Bye Intercooler
disco
hi
I need some advise, I was driving my 2 today when she started to leak boost I checked all my hose clips they where tight I even purchased a new one on the air intake pipe. so I decked the motor on the drive and started to investigate then i noticed that oil was leaking out a split in the intercooler, so its of the road now but what shall i do with it.
1.Get the old intercooler welded
2.Buy a stock 2nd hand intercooler
3.Purchase a new intercooler with a deeper core.
any advise would be very helpfull and if any one has put a uprated intercooler on there motor could you point me in the right direction so i can start looking at prices.
cheers
dave
Speak to Rogue Systems about a 2nd hand one.
An after market is about £600 for a good one.
Or, if you can find one .. a GT4 charge cooler with rad and pumps ..
don't think the is an IC differance .. I know that the Greddy IC is rated, as is the spearco ..
For a proper full thickness one, you can double the price ..
As far as I know, no there isn't a difference. However, there is a difference between MR2 and GT4 intercoolers. I seem to recall that some GT4 intercoolers (later models) are water cooled??
hi
cheers
dave
Talk to Kevin in Droitwich on 01905 778368. He might be able to help you with a used standard replacement.
Yep that's correct...that's were the 10hp difference between the ST205 and MR2 comes from. Custom made would be a cheaper option for a better than factory replacement.
KiwiMR2
Ah yes, the MR2's being 245hp and the GT4 255hp (if memory serves). If you're looking for a stock replacement you could try calling Club MR2 on 0845 458 2108. They're a specialist tuner and brekers down south.
Stock rev3+ in factory condition pushes 253-58bhp. They are rated at 241bhp/245ps) (241bhp.. thats like 15 bhp less than the true figure) mines produced 254bhp stock. Wonder why Toyota play down the figures so much :huh: .
And I wonder if this is the same with the rev1/2 models and thier 225bhp paper figure.
And besides I think rather than spending 600+fitting on an uprated IC the new rougesystems duel fan kit is worth checking out (bout 220 quid I think). Im gonna get one soon. Stock intercoolers for mr2 are bout £50 secong hand I think.
1 word......SUPRA ;)
Didn't wanna make it look bad.
KiwiMR2
Well chaps my latest purchase includes a Greddy side mount intercooler, much like the unit in the middle in this pic:
You can see the STOCK one on the left and a cartech one on the right (Greddy in the middle)
I managed to pick it up for around $24,000 japanese yen ($350.00 nzd's) which is about $125.00 GBP's. Quite a steal considering they go for around $1000 USD's!! I will get new pipes made up for it and no doubt will have to get mounting plates made but otherwise it should be an easy fit when I get my cambelt done!! It has a Greddy Type R BOV plumbed into one of the pipes which I can probably sell for about $200 nzd's so I might make a bit of money back on it :) Also scored a polished front strut brace for the 2 for $100.00 nzd's ($35.00 GBP's) which I haven't seen but will take some pics when it's on :)
Disco....what did you end up replacing your buggered IC with??
KiwiMR2
