Engine Stops P0093
nikyblueys1
i have a LANDCRUISER 3000 D4D and the mil comes on and engine stops .on the diagnossis tool the DTC is P0093
can sombody help me with this problem ?
so you say that if i change the fuel pump i will fix my car?
dose anybody else have this problem how did fix this problem
Thats not what i said, if you try doing a Google search you will find that it could be more than the fuel pump, Toyota will diagnose it as that and charge you a load of money which will not cure the problem.
ok thank1s a lott
i decided to change all4 injectors
will see if this will solve the problem
the car is around 45000 miles and it is from 2008
should have 3 year 60000 mile warranty . i would have thought toyota would sort it.
hello mate
i have no decoder of this code.
Please just clearlly state what has happened in more details.
May be eyou simply have a problem with SCV installed on the pump body???
CHeers/Igor
