Found! Previa And Ipsum Sat Nav Stereo Info!
kiwi240S
i have beeen doing some searching on the net to find out all i can on the toyota sat nav used in previas and ipsums and heres what i came up with.
This will help those tinkerers get the most from these units such as adding dvd's or sat nav into the screen and a few other tricks too.
So you could possibly hook up your Nav unit to your Nav plug using the RGB input, and a dvd via the video input ,AND use the front camera, AND rear camera input also!
ENJOY the links. some are in russian and japanese so put them into google translate for some great "english" captions.
Have a look around and you will find some other great info on these sites.
*Toyota ipsum FAQ and HOW TO. (LOTS OF INFO HERE) (Russian)
forums.drom.ru/toyota-...98309.html
*DVD into toyota ipsum showing how to get dash apart and plugs: (russian)
info.drom.ru/tuning/7548/
*Ipsum/previa stereo speed wire cut to allow video to be used while driving: LOTS OF OTHER GOOD LINKS HERE. (japanese)
www37.tok2.com/home/ao...um101.html
*Toyota previa and ipsum 16029 and 16030 stereo wiring pinouts. (note the rgb video inputs for nav plug (russian)
translate.google.com/t...google.com
*16029 1ND 16030 NAVIGATION HACKS.
CONNECT A PC TO YOUR NAV UNIT AND USE THE TOUCH SCREEN!!!
Probably the best hack so far.
Click on the link made an in car PC and then calibrated the factory touch screen to work with it.
very very cool.
66.249.89.132/translat...LCjTtGgv4g (russian)
*Post 2003 previa stereo pinouts. (russian)
ADD CRUISE TO YOUR '03+ IPSUM AND PREVIA. (SEVERAL DIFFERENT LINKS)
forums.drom.ru/toyota-...34767.html
www.estima.su/2008/06/...stall-diy/
www.geocities.jp/makot...urukon.htm
Click on the lexus link about half way down the "16029 1ND 16030 NAVIGATION HACKS" that i posted above.
a guy made an in car PC and then calibrated the factory touch screen to work with it.
very very cool.
SORRY! EDITED POST ABOVE AS SOME LINKS DIDNT WORK. SHOULD BE OK NOW.PLEASE LET ME KNOW IF THEY DONT
IPOD YOUR FACTORY STEREO!
ADD an ipod to your stereo!
This uses the "AVCLAN" communications between the stereo and the navigation unit.
If you google "AVC LAN ADAPTOR" you will find lots of imformation but here is a good link:
http://www.softservice.com.pl/corolla/avc/
Full touch screen adaptor that allows you to interface with a car pc unit. (run windows media player or winamp!0
http://indashpc.org/new/adapters/car2pc-toy.html
Hres another LAN adptor
the avc lan communications also has the touchscreen imformation on it so you can control a computor via the touchscreen if you interface with it.
  • 4 months later...
Hi
did you manage to modify your factory Ipsum stereo? I've just purchased an Ipsum with a touch screen and looking at options for installing a carputer.
I'm also in New Zealand, and would love to hear how your modifications went.
Cheers
Roger
http://www37.tok2.com/home/aoijf2/ipsum101.html
http://translate.google.com/translate?hl=e...late.google.com
very very cool.
http://translate.google.com/translate?hl=e...le.com(russian)
EDITED THE LINKS AGAIN SO THEY HOPEFULLY WORK gOOGLE TRANSLATE KEEPS OVERRIDING THE ACTUAL WEB ADRESSES AND I CAN'T COPY/PASTE THEM! AAAARRRGH!
USE THE LINKS IN THE TEXT ABOVE THEY SHOULD HOPEFULLY WORK. IF NOT LOG ON TO THE IPSUM CLUB MALAYSIA AND SEE MY POST THERE.
hI rOGER YES I DID GET IT TO WORK.
try the links in the post directly above. also register at the ipsum club malaysia and read this post for more links that actually work. like interfacing the factory touch screen to a PC.
club home page:
http://www.myipsum.net/index.php
MY THREAD:
http://www.myipsum.net/index.php?name=Foru...amp;p=3722#3722
