Rav4 Buying Advice
knightrider
i am going to view a 2.0l GX 1994 in red, on sat for my sister,
wot should i look for wot r the common faults and are there anycostly problems i should look out for?
cheers
lee :thumbsup:
be a right toyota family then
me - yaris
sis - rav4
dad - hiace d4d
Are you buying from a dealership?
If you are, insist a FULL report is available for you to view! I insisted when I recently bought a Freesport for my wife that a B schedule service was carried out along with a FULL detailed report on Brakes tyres, emissions etc.
If you are buying private, ensure a full service history is available + all previous MOT's. Very little goes wrong with them, however, if it does not have solid history ( ie, gaps in servicing, Mot's etc ) leave alone!
I suppose the major items like clutch, steering, gear change, Engine need to be checked thoroughly.
As it's also a 4x4, check for tyre wear, they cost around £80 each to replace.
Hope this helps.
