Cluth Judder/vibration On 2004 1.8 Vvti Petrol
rickjhns
I have just had my clutch replaced by a Toyota delaer on a 2004 1.8 VVTi Petrol. Now I am getting occassional clutch judder/vibration when I pull away in first gear, or when engaging 2nd gear a low speeds.
The only way to avoid this is not use the throttle at all when engaging the clutch. I have taken the car back two times to the dealer and they say they cannot find anyting wrong with the clutch.
In addition, the car has twice made a thud noise ( and I think jumped out of gear) when reversing up a very steep hill. I am not sure if this is related. I am starting to think the issue could be something to do with other transmission components rather than the clutch.
I would appreciate any advice on what could be causing this judder and vibration which sometimes shakes the car.
Many thanks
